Alot of you guys on here don't frequent the boards i do so i thought i'd post up my results of the 441 refresh. Upon tear down and inspection piston 8 was getting it's skirt chewed up for awhile by the relucter ring. Also a big concern was always why it was using oil and the oil was always black no matter the miles on the oil change. Come to find out that the oil scraper ring must have been for a 4 inch bore instead of a 4x1.25 like it was suppose to be because there was about 120 thousands gap!! Piss poor build done and not taking attention to detail to say the least! On to the build.....
Basically same everything from before except for pistons. Had to bore it a tad is why it's a 445 now obviously. Ended up with 13:5 to 1 compression on E85. I'm happy with the results for sure. On the crank dyno we came up with 736/646 with 22 degrees of timing in it. Not bad i guess. Just happy it's back together the right way and running strong. Bash away boys....:lol2:
