this is the motor i have been debating, ripping apart, or running it because it seemed strong and i chose to rip it apart. so ya im pissed now that i pulled the heads and just went all out and pulled everything. the pistons sat on average .021 in the hole, the tiniest bit of ridge wear on few cylinders, the motor is in great shape right now, but i pulled everything, i need to find some standard bore 6cc dish, and im going to mill it .010 and get it up to the 9.1-9.4 range. good old N crank shall get its pilot bushing hole machined in it today
project update
Originally posted by ReRod View PostHoly cow those are old pictures!!
Looks like you're making some nice progress
i dont think this engine will be revved over 5400 rpm anyhow or i would be putting oil restrictors in for sure, i might just do it now and put in a high volume oil pump
-Aaron
87 cutlass
76 olds 350/t56 3.73's
87 olds 442 - old mans ride
355 sbc, th200-4r, 3.73's
Originally posted by GrandmaGold View PostMy good friend Blake just restored his '87 442. I built a 455 for it.
update: the tranny showed up yesterdaycant wait to be
-Aaron
87 cutlass
not too much, just the x member and cutting a hole in the floor, and driveshaft. they make a bellhousing for the swap, and i scored some premade hydraulic clutch pedals for a g body that were on evilbay with a slip on hydraulic t/o bearing. should be a pretty straight forward install, i hope to have it done by the end of april
-Aaron
87 cutlass
update
got my crankshaft today little bit dissapointed that its not a nodular... it has the numbers 242 and a 21? idk. Also my pistons arrived zillner #9374 or badger p518 or fedmog 332np anybody know off hand the cc? I painted the oil pan. Have headers sitting in the garage. the rockers should be in the mail soon then it will all go off to machine work land
-Aaron
87 cutlass
