Cam change and intake swap next week in the bird
Cam change
I am not sure what John is doing but when I am done if it's still there I will get the bird dynoed.
Pulled the cam today, What a little cam
.412 I 193 duration@.050
.428 E 198 duration@.050 on a 111 LCA
The new cam or the HOT cam I have should make quite a difference along with the air gap intake.
Originally posted by bluchev View Posti have a slightly larger cam and springs for ya.
When I put the 4spd in the car it will most likely get the motor that's in the camaro now. That has a 292H in it but I will switch that to the 282S I have before I put itin the car. I like solid lifters. Thanks for the offer though.
IT RUNS boy for a cam that has 218 and 228 duration on a 112CL it sure sounds like a puppy cam, But that's what I wanted. I am sure the elgin hyd I have on the shelf would make this engine sing but that is for another project to be completed in august along with the 4 speed conversion.
