I'm not endorsing Amzoil, nor do I use it in any of my cars. My Camaro SS has had Castrol Syntec in it from day one. I've always changed it at around 2000 miles depending on how hard I run it and it still uses none between changes. My wife's CTS 3.6 calls for Mobil-1 synthetic and after I switched to Syntec, the oil consumption stopped.
Four Ball Wear (ASTM D-4172)The Four Ball Wear Test determines the wear protection properties of a lubricant. Three metal balls are clamped together and covered with the test lubricant, while a rotating fourth ball is pressed against them in sliding contact. This contact typically produces a wear scar, which is measured and recorded. The smaller the average wear scar, the better the wear protection provided by the lubricant. As shown in the graph, AMSOIL Synthetic 10W-30 Motor Oil produced the smallest wear scar of the tested lubricants.
AMSOIL Synthetic 10W-30 Motor Oil provides unsurpassed protection against engine wear. Equipment life is extended, and repairs, down-time and expenses are reduced
