True Power Die Grinder
  • True Power Die Grinder
    This is not really a tip but something that I use all the time when I grind cyl. heads. It is a True Power Die Grinder. It was $49 on Amazon and if it did not work well it's much easier to return to Amazon that feebay.
    This thing is amazing, has an adjustable speed and is very smooth while grinding. There was reviews on it that the tip only take 6mm carbide burrs but that was not the case. It really works well and I do have some heads and intakes that need a little tweaking here and there.
    Got to use the die grinder yesterday and all I can say about it is WOW! this sucker works great at low speeds. Cannot wait to get it on some of my Intakes to port.
      I may have one of these sitting in my amazon cart. just haven't clicked the button
      -Aaron
      87 cutlass
      76 olds 350/t56 3.73's
      87 olds 442 - old mans ride
      355 sbc, th200-4r, 3.73's
        Other than the handle getting warm (wear gloves) it worked great porting the 360 heads. It was nice to be able to turn the speed down and keep on cutting.
